I have the full version Keil uV2 version 2.20a + board C8051F120-TB + USB debug adaptor and run Keil uVision Driver V1.81 for instal.Silab-driver in Keil -connection do not work :( This hardware work ok with uVision3 (evaluation version) (thanks Steve after copy the file USBHid.dll to uv3 directory). I make copy the silabs..drivers from eval.uV3 to full uV2, connection work but I take message 'EVALUATION VERSION...':( Does anyone know to make full KEIL uV2 compatible with USB debug adapter (1.Where to put the SIC8051F_uv2.exe for instal Silab-drivers ? 2.What bottom to press (Modify or Repair) 3.Is this may be the problem :the name directory for My Keil is 'KEIL51'? Yuri (yuri@drive-engineering.com)
uVision V2.20 is too old to work with the SiLABS F120 device. You need the current release of uVision. Reinhard
