Hi I'm trying to use the rtx can functions. However i get a lot of the "REFERNCE MADE TO UNRESOLVED EXTERNAL" type warnings. My guess is that the RTXICAN.lib file doesn't get properly linked. I have added the file to the keil\c51\LIB directory but that doesn't seem to do much. So basicly I would like to know what I am doing wrong here. Thanks in advance Frank Roberts
We are using CAN and RTX51 for years. The issue is the order of the files in the project. In one of our projects it looks like this: 1. Startup.A51 2. Rtxbcan.lib 3. RtxConf.A51 4. BcanConf.A51 and then the rest of the project files. We are using uV2. regards Dejan
I've found the problem. I was using an older project file which had all the correct settings EXECPT for the off chip code memory. The settings caused all the errors when I tried to add the RTXICAN.LIB file to my project. Thank you all for your help
