Because when compiling. The following information appears... MAIN.C(1351): error C249: 'DATA': SEGMENT TOO LARGE Change the small:variables in DATA into the Large:variables in XDATA. While compiling again. The following information will appear.... Could you tell me what kind of situation it is. How to solve?? Help to answer it. THX! *** ERROR L102: EXTERNAL ATTRIBUTE MISMATCH SYMBOL: DDS_DATA_TEMP MODULE: tranCode.obj (TRANCODE) *** ERROR L102: EXTERNAL ATTRIBUTE MISMATCH SYMBOL: DDS_DATA MODULE: DDS_value.obj (DDS_value) *** ERROR L102: EXTERNAL ATTRIBUTE MISMATCH SYMBOL: LATCH_COUNTERvalue MODULE: Counter.obj (COUNTER) *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?ONUSBSUSPEND?MAIN *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?MAIN1?MAIN *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?_TRANSMITDATAEPX?UPSD_USB *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: TIMEINT2 MODULE: initial.obj (INITIAL) *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: SAVEANDRECALL MODULE: initial.obj (INITIAL) *** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL BL51 BANKED LINKER/LOCATER V5.12 09/07/2005 11:41:29 PAGE 161 SYMBOL: TIMEINT2 MODULE: initial.obj (INITIAL) ADDRESS: 848AH . . . . . *** ERROR L118: REFERENCE MADE TO ERRONEOUS EXTERNAL SYMBOL: LATCH_COUNTERvalue MODULE: Counter.obj (COUNTER) ADDRESS: B612H *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: CUSCL_value MODULE: upsd_usb.obj (UPSD_USB) *** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: CUSCL_value MODULE: upsd_usb.obj (UPSD_USB) ADDRESS: B8E3H Program Size: data=174.0 xdata=613 code=47389 LINK/LOCATE RUN COMPLETE. 11 WARNING(S), 131 ERROR(S)
Note that you can look-up the error messages in the Manual: http://www.keil.com/support/man/docs/bl51/bl51_errors.htm You can also click on a messafe, then press F1 to get its description. Don't worry about the fact that you have so many error messages; just look at the 1st three - they tell you that your variables DDS_DATA_TEMP, DDS_DATA, and LATCH_COUNTERvalue all have problems. Therefore, any references to any of these variables anywhere else in your code are also likely to have problems - and each one may generate more messages. Once you've fixed those 1st three errors (as Drew explained), all the rest will probably also disappear!
Once you've fixed those 1st three errors (as Drew explained), all the rest will probably also disappear! With todays compile speeds (anyone know of more than 5 seconds to compile and link) I would - for general purposes - go as far as "Once you've fixed the 1st error some, if not all, of the rest will probably also disappear" If there is no clear picture of whether an error is/could be the result of a previous, do one at a time. Of course, my timing estimate above does not include uVision overhead, it is based on commandline (.bat) operation. Erik
anyone know of more than 5 seconds to compile and link Not that it changes the point, but since you asked: one of my projects takes about 17 seconds to compile all files and about 60 seconds to link. (119 files, a bit under 70K lines of source, roughly 90K of image and 32K of data.) The linker in particular seems noticeably non-linear in its run time with respect to project size. When the project was just a wee nubbin of its current self (say around 8-10 KLOC), compile and link was indeed very quick. And of course when it decides to do its global register re-optimization, it takes four passes and more than four times as long.
OK, I missed that one. Superoptimization may, indeed extend the processing time dramatically. Believing in the NASA philiosophy "we fly what we test" I do not optimize beyond two. You may ask "what does that have to do with testing?". Simply, if a bug is found at optimization 47 there is no way to debug it since the source and object will have very little resemblance and if I can not debug, what is the purpose of writing code. Also, so called "testing" is, in my opinion, worthless as to finding functional problems, it only serves as a means of finding clerical problems. You may have a differnt opinion, I shall not argue beyond what I stated above. Erik
"I would - for general purposes - go as far as 'Once you've fixed the 1st error some, if not all, of the rest will probably also disappear'" Yes, that would be a very good generalisation. "If there is no clear picture of whether an error is/could be the result of a previous, do one at a time." Yes. In this particular case, it is obvious to me that there are 3 distinct "root" errors - so I would fix the 3 and then rebuild. As your method suggests, even with the above observation, I wouldn't bother trawling through all the other messages to try and spot any more unrelated ones - just fix the 3, then address any that are left. But, in general, "fix the first one first" stands.
*** WARNING L15: MULTIPLE CALL TO SEGMENT SEGMENT: ?PR?_FLASH_BOOT_WRITE_WITH_POLL?FLASHCODE1 CALLER1: ?C_C51STARTUP CALLER2: ?PR?USBISR?MAIN Program Size: data=198.0 xdata=608 code=48535 LINK/LOCATE RUN COMPLETE. 1 WARNING(S), 0 ERROR(S) I can not find the question!!!How should I do?
http://www.keil.com/support/man/docs/lx51/lx51_l15.htm
http://www.keil.com/support gives this answer too: http://www.keil.com/support/docs/805.htm Reinhard
