hi ... i am a student looking for a help ... i am very new to keil software and i can't use it ... one of my friends advised me to post a message here ... can any one here send me an educational (PDF) or (WORD FILE)or any thing explaning how to use the software ( from the beginig , i am not looking for software examples ) ... my e-mail is xerox_2050@yahoo.com thank you
http://www.keil.com/support/man/docs/c51/
Hi Mustafa, if you have installed C51 (this is the compiler) respective µVision2 (this is the IDE) you can read the PDF document "Getting Started with µVision2" (Menu "Help"->"Open Books Window") or directly open the file GS51.PDF in directory ..\C51\HLP\*.*. Or: Look at "Support" on the homepage http://www.keil.com/support/default.asp, there are many docs, e.g. Keil Software On-Line Manuals. Greets Martin
"read the PDF document 'Getting Started with µVision2'" This document also contains example projects - so don't just read it, also work through the example projects! There are also plenty of example projects installed in your Keil\C51\Examples folder, and also available in the Downloads section of this very site.
hi first of all ur thinking is wrong i think instead of searching for keil book, i suggest you to download simple keil example analyse it. u will be then master of keil. (i learn in same manner.) hope this will help u.
u will be then master of keil i learn in same manner. I doubt Mustafa will be interested in whether micro becomes a "master of keil" Also, it must be difficult to work with a computer with a defective keyboard, keyboards are cheap, why not go buy one where the 'y' and 'o' works evry ti,e. Erik
please understand short languages. it is not possible for me to give spoon feeding with keyboard . hummmmm i thnk nw u understand it properly.
it is not possible for me to give spoon feeding with keyboard . hummmmm i thnk nw u understand it properly. If you are not willing to speak english (which I am sure you are capable of) and consider it "spoon feeding" to show basic courtesy then I suggest you stop bothering us with your utterances. Stop the Stupid Monkey S***, this is a forum, not a chatbox or a cellphone! It is totally discourteous for you to save maybe 5 seconds and then make 100s of readers spend time to decipher your Stupid Monkey S*** Erik
"i think instead of searching for keil book, i suggest you to download simple keil example analyse it. u will be then master of keil." Rubbish! Just looking at some example code will not tell you, for example, * How to create a new project from scratch; * How to use the IDE effectively; * How to use advanced features of the IDE, like the Source Browser, multiple targets, etc; * How to use the debugger; * Detailed issues of Keil C51's extensions to & departures from the ANSI standard; * etc, etc, etc,... Obviously, you need to both read the Keil books and study the example code. That's why I always say, "Read the uVision Getting Started Guide and work through the example projects in it" (Note the emphasis!)
i'm totally agree with you , and that's what i'm doing now (reading kiel books and studying the examples ).... and i think it gonna worth soon.... THANK YOU ALL GUYS ....... MUSTAFA
It was said: Read the uVision Getting Started Guide and work through the example projects in it" you reply "reading kiel books and studying the examples" DO work through the examples (atually load them on your PC and touch the keyboard) do not just "study" them Erik
