Hi there, I have a development board around the aduc832BS processor and use Keil uVision2 ver2.40 for software development. I tried to implement the 1wire routines for DS18B20 (which i conected at P3.4) but it seems that i have a timing problem.it all starts from the delay function.I use PLLCON=0x051(fcore=8.388608mhz) below is an example of timing delay for DS5000 (8051 compatible) microcontroller with an 11.059MHz clock. //Calling the routine takes about 24us,and //then each count takes another 16us. void delay(int useconds) { int s; for (s=0; s<useconds;s++); } I also know that ADuC832 Machine Cycle Time is nominally 12/Core_CLK. Could you tell me please how can i calculate the timings for the DELAY() (the Machine Cycles required for them) based on the aduc832. (ex. calling time for the delay() routine,calling time for each count in this routine). For the DS5000 the reset routine is: (Reset is 480us, so delay value is (480-24)/16 = 28.5 - we use 29.Presence checked another 70us later, so delay is (70-24)/16 = 2.875 - we use 3). unsigned char ow_reset(void) { unsigned char presence; DQ = 0; //pull DQ line low delay(29); // leave it low for 480us DQ = 1; // allow line to return high delay(3); // wait for presence presence = DQ; // get presence signal delay(25); // wait for end of timeslot return(presence); // presence signal returned } // 0=presence, 1 = no part Thank you in advance for helping me out.
The first and foremost problem is that you're trying to write that delay() routine in C. Don't --- it'll fail to work. Routines that need precise timing at this level are one of the few things that you absolutely have to do in assembler, even on '51. It's likely a mistake to even be trying to do this as a subroutine --- call overhead is likely to disrupt the timing noticeably. So: look up the data sheet for actual instruction timing. Program your delay in assembly language, then calculate how long it should take, using nothing but the data sheet and your hardware configuration data (XTAL, clock dividers, ...). For a cross-check, run it in the simulator and subtract the times spent between two breakpoints surrounding the delay.
"The first and foremost problem is that you're trying to write that delay() routine in C. Don't --- it'll fail to work." Of course it will! It is essential for a delay routine that you know precisely what instructions will be executed so that you can calculate the time it'll take. But the whole point of a High-Level Language like 'C' is that you do not know precisely what machine instructions the compiler will emit! Thus, as Erik & Hans-Bernhard have pointed out, trying to code a precise delay routine in 'C' is futile. "It's likely a mistake to even be trying to do this as a subroutine --- call overhead is likely to disrupt the timing noticeably." Not necessarily - you can include the overhead in the delay calculation; see my post of 11/17/03 15:26:56 in this thread: http://www.keil.com/forum/docs/thread2938.asp Note, however, that I did the above on a 4 cylces/instruction chip at 24MHz - so the overhead will be more significant on an 11MHz 12-clocker...
I've seen your point regarding the keil c++ delay routines. What i can't understand is why Maxim dallas has presented the routines for ds1820 written in C. here it is: http://pdfserv.maxim-ic.com/en/an/app162.pdf After all the Ds500 is pretty much the same as the ADUC832 proc(same 8051 architecture,16mhz clock). Here i found the aduc832 instruction set+osc periods: http://www.analog.com/UploadedFiles/REDESIGN_Quick_Reference_Guides/1015540832qref0.pdf I wonder,is really impossible to estimate the calling time for this delay() and for each count?How did the maxim_team manage to estimate for the ds5000 ? void delay(int useconds)//24us for calling { int s; for (s=0; s<useconds;s++);//16 for each count } Regards, Robert
"I wonder,is really impossible to estimate the calling time for this delay() and for each count?" Nobody said it was impossible. But the only way to do it is to know the precise machine instructions - and you cannot guarantee precisely what machine instructions any compiler will generate. Sure, you can compile it and then examine the generated code and compute the timings for that particular compilation; but you have no guarantee whatever that you will get exactly the same code generated next time - especially if you use a different compiler and/or version, and/or fiddle with the compiler options.
