Respected Colleagues, I can not establish communication between two Keil MCB167 NET boards trough CAN bus using APNT 167 example code. As I see on my scope screen, everything seams to be OK, CAN bit length is the same when transmitting from both boards, levels are OK, etc. but nothing happens on RS-232. I have tried with and without terminating resistors on both boards but boards can not receive anything trough CAN bus from each other. Do I have to make some changes in CAN ID settings or so? Any hint? Thanks in advance. With best regards, Dragan Kujovic
