APNT 167 - CAN Example - I can't make it to work ...
Respected Colleagues,
I can not establish communication between two Keil MCB167 NET boards trough CAN bus using APNT 167 example code.
As I see on my scope screen, everything seams to be OK, CAN bit length is the same when transmitting from both boards, levels are OK, etc. but nothing happens on RS-232.
I have tried with and without terminating resistors on both boards but boards can not receive anything trough CAN bus from each other.
Do I have to make some changes in CAN ID settings or so?
Any hint?
Thanks in advance.
With best regards,
Dragan Kujovic
