Trouble with serial port work.
I was using Keil to program a Philips 89c51 chip last week to transmit data at 19200 bps. It was working perfectly, i got the data on the PC. I could also see the actual 0V - 5V waveforms on the TXD pin.
This week I switched the chip to an Atmel 89c51 33 MHz one..using the same program but can't see thevoltages on the TXD pin. Tried putting a load resistor to ground, then I can see the voltages but the chip is now not speaking to my PC. Do I need to be doing something different..?
thanks for all help..
  • This week I switched the chip to an Atmel 89c51 33 MHz one..using the same program but can't see thevoltages on the TXD pin.
    That's what you get for using Atmel :)
    Seriously: since you state "33 MHz one" did you change the crystal.
    another possibility, since you did not bother to state the whole derivative name (all Philips chips have a 'P') it could be that one was an x2 and the other not. or that one was programmed as an x2 and the other not because the (default and?) programming is different.
    a third possibility, since you did not bother to state the whole derivative name is that one chip has configurable pins .
    a fourth possibility, since you did not bother to state the whole derivative name is that the UART activation differ.
