Is there any way to run the Keil simulator debugger without opening the Keil IDE. I mean is there any option to run the program from command line and capture the output of the program in a file.
yes
Can u give me the information on how to do.
"Is there any way to run the Keil simulator debugger without opening the Keil IDE." No "I mean is there any option to run the program from command line and capture the output of the program in a file." Yes - see "Command Line" in the manual
