I have got a problem with my funtion to convert an array to float. I use the "Debug" to see the value of my variables. The problem is in the multiplication on the second element of array fd[1] only when there is a "7","8" or "9", for example to convert "070000" the value of bux=4464, for others value the funtion works perfectly.
float Conv_C2F_FE(unsigned char fd[6]) {float bux; bux=(fd[0]-0x30)*100000; bux=bux+(fd[1]-0x30)*10000; bux=bux+(fd[2]-0x30)*1000; bux=bux+(fd[3]-0x30)*100; bux=bux+(fd[4]-0x30)*10; bux=bux+(fd[5]-0x30); return bux; }
"The problem is in the multiplication on the second element of array fd[1] only when there is a '7','8' or '9' You are multiplying by 10,000. Think about what "magic number" occurs between 6*10000 and 7*10000... Hint: 16 bits...
It is left as an exercise for the student to determine why you don't get a problem multiplying by 100,000...
