Hi, How can I produce an assembly file from a C or Hex file in Keil? Thanks in advance
These are two completely different operations! The 'C' compiler can generate assembler output - see the SRC directive. A Disassembler takes Hex and translates it to Assembler. The Keil Debugger & Simulator include a Disassembler.
