hi: I installed the DK-ARM dev tools,including uv3 IDE and GNU gcc which are both supplied by the keil company.I opne the Demo project: keil\arm\gnu\measure\measure.uv2.Nothing to do but directly click the "build" icon on tool bar.However,the output window of uv3 IDE tells me the following error information: Build target 'AT91M55800A' assembling Startup.s... --- Error: can't execute 'arm-uclibc-as' Target not created I,m a beginner of arm,and don't know what's wrong with the Demo application.Thanks for giving me the right answer.
Two questions. 1. Where did you install the GCC compiler? Did you use the default installation folder? 2. Why not use the Keil compiler and assembler? Jon
1. Where did you install the GCC compiler? Did you use the default installation folder? answer: I bought DK-ARM development tools for ARM7 in china.All of the installing program are from the CD-ROM which supplied by keil.I installed the UV3 IDE and GCC(cygnus) in Windows2000 professional(sp4,chinese).And the install directory is default(c:\keil,c:\cygnus). 2. Why not use the Keil compiler and assembler? answer: Keil only supplys GCC in DK-ARM tools.Paying more money for keil's CA and AA which are supplied in PK-ARM tools.
1. The error you get typically indicates that the GCC compiler can't be found. 2. The BETA release of the Keil assembler/compiler/linker are included for FREE in the DK-ARM. They are much easier to use and configure than the GNU tools. Jon
