I'm trying to put 2 config chars into ROM (user makes a change which the ROM remembers during power down). However on compiling I get: 'error C142: illegal initialization' and then 'warning C34: 'code' : missing declaration specifiers The code I am using is as follows: code const unsigned char Config1 = 0x00; code const unsigned char Config2 = 0xA0; Can anyone tell me what is going on. Thanks
Thanks Bruno. I think I'm just going to have to stick on a 8 pin Flash device to get around the problem.
About the chip: in the past there were some C167-CS flash derivatives (SAx C167-CS 32FM) integrating some amount of Data Flash, acting like the eeprom you are searching for, but they were engineering samples and they have never been released for volume production. Data Flash is present in all C167-CS 32FM chip steps until DA, from DA step Data Flash has been cancelled.
"Does a const value allow you to change it at runtime and retain it's value on power loss?" No. const is simply a hint to the compiler that it should not let you write to the variable. I think you need to buy a good 'C' textbook.
"I'm still waiting for the databook. I just didn't want to sit on my hands until it arrived." Pardon?! Welcome to the 21st Century - don't wait for a clumsy databook, download it now! http://www.keil.com/dd/cl/all/166.htm
Thanks for your help Mike. I'm still waiting for the databook. I just didn't want to sit on my hands until it arrived.
To the best of my knowledge, there are no MCUs with on-chip EEPROM among C166 derivatives. There are chips with on-chip flash ROM, but apparently that's not what you are after. So yes, you'll have to put something external on for just two bytes. But really we should not be the ones to explain you all this. It's all in the datasheet of the chip you are using. Just read it. Regards, - mike
Exactly which C166 derivative are you using? http://www.keil.com/dd/cl/all/166.htm Jon
there is no such thing as code keyword. This is replaced by const.
There lies the problem, I've only been on this chip for a week. I'm assuming it has some sort of internal EEPROM that can be read/written at runtime. Don't tell me I have to put something external on for just two bytes.
Now that we know that it's about C166, it's easy to say why the compiler complained. There is no code keyword, so naturally the offending code looks like rubbish to the compiler. As for the use of non-volatile memory in your application, I'm not at all sure how your are going to achive what you just described with that code. I hope you know what your are doing... Regards, - mike
I'm using a C166. The idea is that I have two bytes stored in some sort of non volatile memory that I can change at runtime. As I make changes to the attached hardware, my software stores the values in NV memory, which can then be recalled upon next power up and used to set up the hardware.
"user makes a change which the ROM remembers..." How will the ROM remember it...?
Are you talking about C51 or C166 (as the thread header suggests) ? Because in C166, there is no such thing as code keyword. - mike
Version 3
