Hi everyone, I have a Keil C166 code + addon disk from a few years ago which was working just fine ("9.2000" is what it says on my disk). I foolishly tried to install a slightly newer version of the Keil toolset over my working copy, and now I have a problem I can't seem to fix. It seems the Keil tools are convinced that I have the Rainbow Sentinel dongle (which I don't, and never needed), and they will not run without it, even after several re-installs, registry searching and deleting, etc.
DRIVER NOT INSTALLED
Calvin, Suggest that you contact Tech Support. There was an earlier thread that I cannot locate that mentioned a couple of US packages got out that required a dongle where previously no dongle was required. Also, while seaching for the mentioned thread, I read where there will be no dongles on any future packages. I know that doesn't help you. Just thought I would mention in passing. Bradford
