hi everyone I'm looking for a good alogrithm to send a float variable to a PC by the serial port. First I have to separate the float variable in bytes to be read to send by the serial port. do i have to send the variables in binary or ascii?? what do you recommend me?? Another problem is in the pc.. if I want to use visual basic to print the value how can I join the bytes to have the real float variable?? thanks
"Another problem is in the pc.. if I want to use visual basic to print the value how can I join the bytes to have the real float variable??" No idea! :-( This is a Keil forum, not a Microsoft and/or VB forum - so you'll have to read your VB documentation, visit MSDN, and/or find a VB forum for that one.
Can't help you with the VB, but here is a method that works great for uC to Labview over a serial port. Consider the following code snippet union { float floater; unsigned char string[4]; unsigned long int longinter; unsigned int interger; } float_char; char sendbuf[4]; float_char.longinter=MS_COUNTER_REF; sendbuf[0]=float_char.string[0]; sendbuf[1]=float_char.string[1]; sendbuf[2]=float_char.string[2]; sendbuf[3]=float_char.string[3]; UART0_Xmit(sendbuf, 4);//send 4 bytes float_char.floater=neon_pressure; sendbuf[0]=float_char.string[0]; sendbuf[1]=float_char.string[1]; sendbuf[2]=float_char.string[2]; sendbuf[3]=float_char.string[3]; UART0_Xmit(sendbuf, 4); end of code This results in sending out 4 bytes that make up a 32 bit floating point number. In labview, they have a unflatten from string function with will decode from 4 element string to 32 bit floating point. If VB has something equivilent, this may work for you. Hope this helps AC
Hi AC I'm very interested in the code for labview can you tell me your email. because I need to graph some value from my microcontroller. please help me thanks
You might want to take a look at http://www.windmill.co.uk They have loads of stuff (including free stuff) for getting serial data into Excel, and other PC things
Jean Paul, You can reach me at acurda@amsuper.com I can give you an example of converting such data to a floating point in labview if you need. I can try to help with other stuff if yo have specific question, but sometims this darn work thing gets in the way. Andy
Jean Paul, I sent you some examples but got another email from you. What country are you in anyway? You should of recieved 2 emails from me by now. Let me know here if you havn't recieved any email from me. Andy
