XC161, Does a PEC transfer interrupt a EXTS Sequence
My application needs very fast PEC response times.
As i can see in the ".lst" file, the Keil compiler uses EXTS sequences for long addressing memory access:
EXTS #014H, #04H
MOV R5, [R9]
MOV R6, [R9 + #SOF(02H)]
MOV R7, [R9 + #SOF(04H)]
MOV R8, [R9 + #SOF(06H)]
What happens, if a PEC event occurs during the EXTS seqence? Does the PEC transfer interrupt the EXTS Sequence, or is the PEC tranfer delayed until the EXTS sequence is finished?
  • According to the instruction set manual.
    Notes on the ATOMIC and EXTended Instructions
    These instructions (ATOMIC, EXTR, EXTP, EXTS, EXTPR, EXTSR) disable standard and PEC
    interrupts and class A traps during a sequence of the following 1...4 instructions.
    Took all of 30 seconds to find it.
