Can't connect to target
Today I started working with a Cypress EZ-USB
FX Development Board. I downloaded devtools
version 2.61 After I connected my board
to the computer I run EZ-USB control panel
and loaded the target with dev_io.hex. I
tested it and everything worked just fine.
Then I wanted to test the same program
in Keil uVision2 V2.10, but without succes.
Everytime when I want to go to Debug mode,
I get a message that says: Try Again!
I've checked the cables and the settings,
but I could not find any mistakes. Has
anyone had the same problems as I am having
now?
Kind regards,
Chris
