Trying to enter for example sendCANmessage (0) into the command line of the Simulator (µV2, Target C515C) the µV2-IDE says "Good-Bye" to me. The same happens at every not-default (user-defined) command when "Space" or a bracket is entered. Even the latest update shows this behaviour! Has anybody else out there seen this problem before and knows how to fix it?
There's altogether not enough context in that question to make it answerable... The first suspicion would fall into the direction of your user-defined functions themselves. How sure are you that their definitions are correct? Did you try without any definitions of such loaded at all? With only a single, trivial do-nothing function?
