I'm using Floating license for my keil and able to compile the code successfully but when I run in debug mode I'm getting "Error: *** License Mapping Failed! *** Debugger aborted !" error. Can anyone help me on this.
Thanks in advance.
Domneck
So is this error coming form Keil uVision, or from the J-Link:
forum.segger.com/.../
Hi Andrew
Even this is posted by me.
Segger says there is no such error message in their database.
Regards, Domneck
and they also gave you a way to check ...
If you do have a valid Keil licence, then you should contact Keil direct for support with Keil licensing issues ...
