Hello Sir,
My project was to drive a DC motor with LCD display using fingerprint sensor (AD-013) capacitive type sensor module. please help me to get the code and schematic diagram od microcontroller.
there is a link to consultants
If it's "Your" project, then shouldn't you be the one doing the work? Or, at least, shouldn't you be the one doing the googling?
Hint: as well as just a straight google search, doing a search in GitHub is a good idea when searching specifically for code ...
Other search engines are available
sir i was able to find any link for the same. please help me
You mean you were not able?
What, exactly, were you expecting to find?
You shouldn't expect to find a complete ready-made answer which exactly manages your complete homework assignment!
Rather, look for parts to get you started.
Your homework assignment consists of 3 very common parts:
1. drive a DC motor;
2. drive an LCD;
3. drive the fingerprint sensor.
There should be plenty of stuff on the interwebs featuring each of these things - your job is to learn from them, take the parts appropriate to your homework, and bring them together to make your system.
Basics of interfacing anything to anything else: www.8052mcu.com/.../160143
is your homework in a class of copying ? I have not heard of such a course
My difficulty is to intract with AD-013 type Fingerprint module as the enrollment and search task is seems a bit tuff at my point.
So this has nothing to do with Keil, then?
What have you tried?
Where, exactly, are you stuck?
When stuck with your homework, you should be going to your teachers for help.
There are a number of well-supported fingerprint modules available from the popular maker/hobbyist suppliers - perhaps you would be better off using one of those...?
While all of the criticism targeting the OP is justified, I'm afraid he and his ilk will have to deal with a trauma for live after leaving here :-)
Is that worse than the trauma of being caught out cheating on your homework ... ?
www.8052mcu.com/.../60122
www.8052mcu.com/.../8648
