uVision IDE alternatives?
I'm using uVision 5.25, and this IDE is difficult to work with. So I would like to use a different IDE that supports the Keil ARM toolchain. I see that Keil has an Eclipse IDE plugin for uVision 4 projects but not for version 5.
Is there an alternative IDE for Windows?
Here are some of the issues I have with uVision that make it difficult.
- When adding files to a group, if the files are scattered in a directory tree with subdirectories, I have to search for the files to add them.
- The editor windows are not synced with the project window.
- The project window can't sort files alphabetically.
- Repositioning docked windows are not saved and move back to their default position when uVision is reopened. I run the program as Administrator.
- The functions window lists all the functions in the project, not the current edit window's functions.
- I can't add new projects to a multi-project workspace. I have to destroy the workspace file and then create the new projects.
I find more annoyances and difficulties each time I use uVision.
