HI,I Want use gun in keil.now,Can't output debug log to uart.I have implement fputc like this: int fputc(int ch, FILE *f) { if (s_debugInit) { UART_SendData(DEBUG_UART, ch); } return ch; } but when I call printf,don't call fputc function.what's worry?Thanks for your help!
I have add syscalls.c in my keil project.
syscalls.c
#include <stdlib.h> #include <errno.h> #include <string.h> #include <sys/stat.h> #include <sys/types.h>
int _read_r (struct _reent *r, int file, char * ptr, int len) { r = r; file = file; ptr = ptr; len = len;
errno = EINVAL; return -1; }
int _lseek_r (struct _reent *r, int file, int ptr, int dir) { r = r; file = file; ptr = ptr; dir = dir;
return 0; }
int _write_r (struct _reent *r, int file, char * ptr, int len) { r = r; file = file; ptr = ptr;
#if 0 int index;
/* For example, output string by UART */ for(index=0; index<len; index++) { if (ptr[index] == '\n') { uart_putc('\r'); }
uart_putc(ptr[index]); } #endif
return len; }
int _close_r (struct _reent *r, int file) { return 0; }
/* Register name faking - works in collusion with the linker. */ register char * stack_ptr asm ("sp");
caddr_t _sbrk_r (struct _reent *r, int incr) { extern char end asm ("end"); /* Defined by the linker. */ static char * heap_end; char * prev_heap_end;
if (heap_end == NULL) heap_end = & end;
prev_heap_end = heap_end;
if (heap_end + incr > stack_ptr) { /* Some of the libstdc++-v3 tests rely upon detecting out of memory errors, so do not abort here. */ #if 0 extern void abort (void);
_write (1, "_sbrk: Heap and stack collision\n", 32);
abort (); #else errno = ENOMEM; return (caddr_t) -1; #endif }
heap_end += incr;
return (caddr_t) prev_heap_end; }
int _fstat_r (struct _reent *r, int file, struct stat * st) { r = r; file = file;
memset (st, 0, sizeof (* st)); st->st_mode = S_IFCHR; return 0; }
int _isatty_r(struct _reent *r, int fd) { r = r; fd = fd;
return 1; }
/*** EOF ***/
