GCC+Keil printf cann't retarget to uart
HI,I Want use gun in keil.now,Can't output debug log to uart.I have implement fputc like this:
int fputc(int ch, FILE *f)
{ if (s_debugInit) { UART_SendData(DEBUG_UART, ch); } return ch;
} but when I call printf,don't call fputc function.what's worry?Thanks for your help!
I have add syscalls.c in my keil project.
syscalls.c
#include <stdlib.h>
#include <errno.h>
#include <string.h>
#include <sys/stat.h>
#include <sys/types.h>
int _read_r (struct _reent *r, int file, char * ptr, int len)
{ r = r; file = file; ptr = ptr; len = len;
errno = EINVAL; return -1;
int _lseek_r (struct _reent *r, int file, int ptr, int dir)
{ r = r; file = file; ptr = ptr; dir = dir;
return 0;
int _write_r (struct _reent *r, int file, char * ptr, int len)
#if 0 int index;
/* For example, output string by UART */ for(index=0; index<len; index++) { if (ptr[index] == '\n') { uart_putc('\r'); }
uart_putc(ptr[index]); }
#endif
return len;
int _close_r (struct _reent *r, int file)
{ return 0;
/* Register name faking - works in collusion with the linker. */
register char * stack_ptr asm ("sp");
caddr_t _sbrk_r (struct _reent *r, int incr)
{ extern char end asm ("end"); /* Defined by the linker. */ static char * heap_end; char * prev_heap_end;
if (heap_end == NULL) heap_end = & end;
prev_heap_end = heap_end;
if (heap_end + incr > stack_ptr) { /* Some of the libstdc++-v3 tests rely upon detecting out of memory errors, so do not abort here. */
#if 0 extern void abort (void);
_write (1, "_sbrk: Heap and stack collision\n", 32);
abort ();
#else errno = ENOMEM; return (caddr_t) -1;
#endif }
heap_end += incr;
return (caddr_t) prev_heap_end;
int _fstat_r (struct _reent *r, int file, struct stat * st)
memset (st, 0, sizeof (* st)); st->st_mode = S_IFCHR; return 0;
int _isatty_r(struct _reent *r, int fd)
{ r = r; fd = fd;
return 1;
/*** EOF ***/
  • Please try reading the instructions about posting source code again.
    Does it call _write_r() ?
    What part? Does UART_SendData() expect you wait on TXE?
    Normally GNU/GCC wants you to output to UART via _write()
    int _read (int file, char *ptr, int len)
            int DataIdx;
            for (DataIdx = 0; DataIdx < len; DataIdx++)
                    *ptr++ = __io_getchar();
    return len;
    int _write(int file, char *ptr, int len)
            int DataIdx;
                    __io_putchar(*ptr++);
            return len;
    Where you implement the specifically targeted __io_ functions
            int DataIdx;
    return len;
            int DataIdx;
            return len;
