We are currently working on a Web server on an ARM Cortex-M7 to transmit JSON string via HTTP and CGI. When sending TCP / IP packets (2 or 3 TCP segments), an error occurred: net_sys_error NET_ERROR_MEM_CORRUPT. This error occurs randomly after X send TCP / IP packets.
Before the error occurs, the HTTP server sends only one TCP segment (1440 bytes) instead of 3 TCP segment (2989 bytes). We can not find the cause of the problem.
Card: STM32F769I
Versions: HTTP_Server_FS.c: v7.2.0 HTTP_Server_CGI.c: v7.0.0 Net_Config.c: v7.7.0 (variant IPv4 / IPv6 Release) Net_Config_HTTP_Server.c: v7.0.0"
Config: Net_Config.c Core Thread Stack Size : 5120 bytes
Net_Config_ETH_0.h Interface Thread Stack Size : 1024 bytes
startup_stm32f769xx.s Stack Size : 800 bytes Heap Size : 8190 bytes
RTX_Conf_CM.c Number of threads with user-provided stack size : 2 Total stack size for threads with user-provided stack size : 6144 bytes
Thanks in advances,
Best regards
Update :
Just after the error: ERR_MEM_CORRUPT, the Fault Report report reports a Bus Fault error: IMPRECISERR
Below link will help you to troubleshoot the error: www.keil.com/.../network_troubleshoot.html
