STR instruction in ARM assembly doesn't work using MDK-ARM(version 5.26)& Legacy support for ARm 7. Is there any way to store data in memory from a register in ARM7?
Hello Grace,
Sorry to hear you are having issues with STR. How do you know the instruction is not working?
What compiler toolset are you using ? Arm compiler 5 (ARMCC), or ARM Compiler 6?
If you are using ARMCC, did you see these links? www.keil.com/.../armasm_dom1361289906890.htm
www.keil.com/.../armasm_dom1361289907270.htm
www.keil.com/.../armasm_dom1361289907680.htm
Hello Ron,
Thank you so much for your quick response!!
I had an ERROR 65 (no 'Write' permission). That's the reason that STR didn't work. I fixed it.
Thanks, Grace
That's a Simulator error, isn't it?
http://www.keil.com/support/man/docs/uv4/uv4_e065.htm
http://www.keil.com/support/docs/814.htm
Nothing to do with the Assembler.
Yes, your are right!
