I am currently using a µvision V5.26.2.0 and sometimes I can't save source file ( h , cpp ).
When it happened the pop ups window showing this message:
"Encountered a sharing violation while accessing {Path to me source file}"
The only one way that can change this behavior is to restart the µvision IDE.
Can I do something else?
Same sharing problem with me. Only observed it since about 1 month. In one environment at work, local folder is observed by GitHub, on other environment it's on a dropbox folder. (I used to work on dropbox folders for about 2 years, never happened) Only *.h files seem to be affected. The IDE shows the latest edited version but trying to save it, pops this message. I can copy the content, create a new file, save it,then restart IDE. Otherwise all editing is lost.
for about a week I did not have the issue anymore.. Vague Theory: Micro Soft patch started sharing problem, now with another patch it disappeared?
ups, happened again.. so vague theory is false :)
