I am currently using a µvision V5.26.2.0 and sometimes I can't save source file ( h , cpp ).
When it happened the pop ups window showing this message:
"Encountered a sharing violation while accessing {Path to me source file}"
The only one way that can change this behavior is to restart the µvision IDE.
Can I do something else?
MDK development team is working on a solution now. This "sharing violation" issue should be fixed in the next MDK release (newer than MDK v5.26))
Does that mean they've identified the problem?
If so, is there anything people can do to avoid it while we await the solution?
Is it purely an ARM MDK thing, or are the other architectures also affected?
I've seen this error only once after update to 5.26.2, on Win10 1803. When this error pops up, changes made in the IDE in affected files are lost, even the files appear as saved. So if you made valuable changes, copy the affected file out of the editor and save elsewhere. Have not seen this with other apps.
-- pa
As in my case, I am developing in Win 7 and it happens at least twice in a day.
