I am currently using a µvision V5.26.2.0 and sometimes I can't save source file ( h , cpp ).
When it happened the pop ups window showing this message:
"Encountered a sharing violation while accessing {Path to me source file}"
The only one way that can change this behavior is to restart the µvision IDE.
Can I do something else?
Same issue here. Win10, all work done on local hard drive, sharing violation with my header files, sporadically. Sometimes they save, sometimes they don't. Hoping for a fix soon.
It has already been fixed, see above (stupid order when looking thru the thread) I have a version that has been running perfect for a week now, will be released by ARM/Keil in the near future
Just to add, the fix will also be available with next MDKv5.27 pre-release which will be available around Christmas and will be available to download from http://www2.keil.com/mdk5/
Just as a note, I'm running with the new 5.27 prerelease and I now (although seldom) see "Error number: 22" when saving a .h file. So it seems the error is not completely gone (at least not for me). The frequency of it is however much lower than before!
Hello All,
You can download the 'MDK v5.27 pre-release' by going to http://www2.keil.com/mdk5/ and
Clicking the "Download MDK v5.27 pre-release" button.
Direct link:
www2.keil.com/.../527pre
This edition should resolve most users issues with sharing violations.
Best regards,
Kevin
"most" ?!
It is called hedging..
What did the underlying issue turn out to be?
would be interesting to know!
We made were making the IDE more robust, but were checking things in an order that could sometimes cause an issue.
Re-arranging the process that we did that seems to resolve the issue that sparked this thread.
Am using release 5.27 and something similar popped up again.
On recent closure there was an error for saving a header file with error number 22.
Seng Tak
I'm still using an older version. Is this bug now fixed?
Regards, R
Yes, I have not seen it since it was fixed (I'm running 5.27)
Haven't seen the issue crop up in months of use. Using 5.27 currently
It does still occur but not as often. I still sometimes get an error stating that uVision is unable to save the file (I don't remember the exact message). I then have to quit the IDE and restart to solve the problem. I have seen this on V5.27 and V5.29.
Same problem. Keil 5.29. Annoying. Fixed or not?
The primary issue that spawned this thread was resolved.
You might get a similar error unrelated to the primary.
Unfortunately just saying "me too" with out any contextual detail isn't going get you much help.
Start a new thread for 5.29 issues, providing specific details on your system, including those about software running, like AV, connectivity and where the problem files reside, etc. Also what interactions with the IDE tend to precipitate the failure most often.
