Hi all. I use ARM LPC2148 for my project and i use Keil uVision4.
µVision V4.60.0.0
Tool Version Numbers: Toolchain: MDK-Lite Version: 4.60.0.0 Toolchain Path: C:\Keil\ARM\ARMCC\bin\ C Compiler: Armcc.Exe Assembler: Armasm.Exe V5.02.0.28
I have a problem with interrupt handler irq. I write the following code in language c:
#include <lpc214x.h>
void tc0(void)__irq; unsigned i = 0; void main(void) {
PLL0CFG=0x24; //Multipler and divider setup PLL0CON=0x01; //Enable PLL PLL0FEED=0xAA; //Feed sequence PLL0FEED=0x55; while(!(PLL0STAT & 0x0400)) ; //is locked? PLL0CON=0x03; //Connect PLL after PLL is locked PLL0FEED=0xAA; //Feed sequence PLL0FEED=0x55; VPBDIV=0x01;
VICIntSelect = 0x00;
VICVectAddr0 = (unsigned long)tc0; VICVectCntl0 = 0x20 | 4;
VICIntEnable = 0x10;
T0MCR = 0x03; T0MR0 = 0x00003000; T0TCR = 0x01;
while(1) { //loop } }
void tc0(void)__irq { i = 1; T0IR = 0x01; VICVectAddr = 0x00; }
Some specific problem or should we guess?
Check clocks. Check timer in debuggers peripheral view.
Please post your home address here. I only reply via traditional mail.
