Code doesnt run after 'write flash' stm32f4
I have a strange situation, code works fine in st link debugger mode. But when i press f8 which means write code to flash, and reset the device - seems like code not running. i use stm32f407 discovery board with st link debugger. what it can be? please help, im out of ideas
  • On other boards might worry about BOOT0.
    Chances here is that the board/chip is running, but stuck in a timeout or error loop.
    Try instrumenting the code so you know how deep it got. Try not using HSE/PLL and just run from 16 MHz HSI which the processor starts with. Loop and Error_Handler() and Hardfault_Handler() routines, output details if you hit either point, or any other while(1) loops you have in your code.
