Hi all, I'm using uVision 5.23, i've got some problem with SAVE command. I need to make a command button which make a memory dump using the "SAVE xxx.hex 0xC0000000,0xC0001000" command. It work fine if i send it from command window, instead if i try use it in the initialization file i got a syntax error message. This is my initilization file: ---------------------------------------------- KILL FUNC * KILL BUTTON *
FUNC void SaveBuffer(void) { SAVE xxxx.hex 0xC0000000,0xC0001000; }
define button "Save Buffer", "SaveBuffer()" ----------------------------------------------
this is the error message when debugger start: ---------------------------------------------- Include "C:\\SISTEMI DI SVILUPPO\\ARM\\_REVERBERI_ENETEC_\\SLV_WL\\trunk\\MDK-ARM\\dbgInit.ini" KILL FUNC * KILL BUTTON *
FUNC void SaveBuffer(void) { SAVE xxxx.hex 0xC0000000,0xC0006000 _^ *** error 10, line 5: Syntax error *** Function creation aborted due to syntax errors BS \\SLVarm\../Myfunction/Image_processing.c\141 ----------------------------------------------
someone can help me?
instead of:
always use the exec() function when a debugg command needs to be executed from within a debug function:
FUNC void SaveBuffer(void) { exec ("SAVE xxxx.hex 0xC0000000,0xC0001000"); //---with path use: //exec ("SAVE C:/temp/xxxx.hex 0xC0000000,0xC0001000"); //---or (note the double backslash characters): //exec ("SAVE C:\\temp\\xxxx.hex 0xC0000000,0xC0001000"); }
Thank you
