Is it possible please to set a source file path using an environment variable.
example:
$REPO$\project\test instead of C:\IDE\project\test (where REPO = C:\IDE
Thanks and regards, Nawres
maybe I should say, it can use relative paths - so make sure your project takes advantage of this ...
uVision uses relative paths - so you shouldn't need to do that.
Also, have a look at this: http://www.keil.com/support/man/docs/uv4/uv4_ut_keysequence.htm
