Hi, The test code is listed as below,
#pragma OT(0) void main (void) { DATA_MSG *b=NULL; DATA_MSG *a=NULL; b=(DATA_MSG *)malloc(sizeof(DATA_MSG)); b->sMsgHeader.MessageType=E_Battery_Status; b->sMsgHeader.Extended=1; //Plug_Status=0; //Varible_Init(); a=(DATA_MSG *)malloc(sizeof(DATA_MSG)); a->sMsgHeader.MessageType=E_Get_Country_Info; a->sMsgHeader.Extended=0; if(b->sMsgHeader.Extended || a->sMsgHeader.Extended) EX3=1; else EX3=0;
I use the keil-C simulator to debug it. I found the pointer a and b point to the same memory location. It means that the a overwrites b, I don't know why? Anyone knows it? Thanks a lot.
Dynamic memory allocation is generally avoided in small embedded systems - like 8051.
Why do you feel the need for Dynamic memory allocation here?
You do not check that malloc() succeeded before using the pointer - this is a recipe for disaster!
Have you properly configured your Heap ?
BTW
Having selected 'Cx51, 8051, or MCS51' as your Architecture/Product, there's no need to repeat that in your title
the '51 is NOT a PC dynamic memory allocation should be avoided like the plague (MISRA does not allow it)
I only see mallocs etc when the coder is PC trained and believes the '51 is "just another processor"
are you the ghost of Erik Malund ... ?!
