I try to my board. I use stm32f3 and I use SWD(sclk-swdio-gnd-3,3v-nrst) pins for programming board. In setting, debugs I show my processor after I try to load my code but keil send "Core is held in reset" I dont load code.
So you need to find what is holding it in reset, then ...
Yes, I need to find what is holding it in reset but I dont find
You have the hardware and the schematics in front of you.
If you can't work it out with the hardware and the schematics in front of you - how on earth do you expect complete strangers to do it remotely with absolutely no idea what your hardware is??
Ho its schmatic [url=https://hizliresim.com/PDkzz6][img]i.hizliresim.com/.../url]
i.hizliresim.com/PDkzz6.jpg
you're link does'not wurk
Another link: www.imgim.com/20180702_142355.jpg
thats looks very compilcated. have u got it in the simulator. quorus is very good simulation.
The part will clamp NRST based on threshold voltage on VDDA
What debug pod? For ST-LINK make sure using current firmware rather than V25/26
If on a NUCLEO/DISCO board make sure to properly disconnect on-board target, see jumpers and solder bridges.
