I'm trying to set up a 33333 bus that uses a single wire for can. Took a bit to get the 33333 configured but now it seems to have issues with receiving. Putting a break point at CAN2_SignalObjectEvent's checks never triggers. This set up below is for a dual wire CAN, do I need to combine the RX/TX to make it work for single wire? How would I go about this?
#define CAN_CONTROLLER2 1 // CAN Controller number (can 1 is pa12/11) (can 2 is pb12/13) //------------------------------------------------------------------------------ #define _CAN_Driver_(n) Driver_CAN##n #define CAN_Driver_(n) _CAN_Driver_(n) extern ARM_DRIVER_CAN CAN_Driver_(CAN_CONTROLLER2); #define ptrCAN (&CAN_Driver_(CAN_CONTROLLER2)) uint32_t rx2_obj_idx; uint8_t rx2_data[8]; ARM_CAN_MSG_INFO rx2_msg_info; uint32_t tx2_obj_idx; uint8_t tx2_data[8]; ARM_CAN_MSG_INFO tx2_msg_info; static int ID_Read; static int _TIMEOUT = 100;//each 100 is a second void CAN2_SignalUnitEvent (uint32_t event) { switch (event) { case ARM_CAN_EVENT_UNIT_ACTIVE: break; case ARM_CAN_EVENT_UNIT_WARNING: break; case ARM_CAN_EVENT_UNIT_PASSIVE: break; case ARM_CAN_EVENT_UNIT_BUS_OFF: break; } } void CAN2_SignalObjectEvent (uint32_t obj_idx, uint32_t event) { if (event == ARM_CAN_EVENT_RECEIVE) { // If receive event if (obj_idx == rx2_obj_idx) { // If receive object event ptrCAN->MessageRead(rx2_obj_idx, &rx2_msg_info, rx2_data, 8U); ID_Read = rx2_msg_info.id; printf("single caught:ID_Read &i \n", ID_Read); } } if (event == ARM_CAN_EVENT_SEND_COMPLETE) { if (obj_idx == tx2_obj_idx) { } } } bool CAN2_Initialize (int CAN_BITRATE_NOMINAL) { ARM_CAN_CAPABILITIES can_cap; ARM_CAN_OBJ_CAPABILITIES can_obj_cap; int32_t status; uint32_t i, num_objects, clock; can_cap = ptrCAN->GetCapabilities (); num_objects = can_cap.num_objects; status = ptrCAN->Initialize (CAN2_SignalUnitEvent, CAN2_SignalObjectEvent); if (status != ARM_DRIVER_OK) { return false; } status = ptrCAN->PowerControl (ARM_POWER_FULL); if (status != ARM_DRIVER_OK) { return false; } status = ptrCAN->SetMode (ARM_CAN_MODE_INITIALIZATION); if (status != ARM_DRIVER_OK) { return false; } clock = ptrCAN->GetClock(); if ((clock % (10U*CAN_BITRATE_NOMINAL)) <= 300U) { status = ptrCAN->SetBitrate (ARM_CAN_BITRATE_NOMINAL, CAN_BITRATE_NOMINAL, ARM_CAN_BIT_PROP_SEG (1U) | ARM_CAN_BIT_PHASE_SEG1(5U) | ARM_CAN_BIT_PHASE_SEG2(3U) | ARM_CAN_BIT_SJW (1U)); } else if ((clock % (8U*CAN_BITRATE_NOMINAL)) == 0U) { status = ptrCAN->SetBitrate (ARM_CAN_BITRATE_NOMINAL, CAN_BITRATE_NOMINAL, ARM_CAN_BIT_PROP_SEG (5U) | ARM_CAN_BIT_PHASE_SEG1(1U) | ARM_CAN_BIT_PHASE_SEG2(1U) | ARM_CAN_BIT_SJW (1U)); } else if ((clock % (10U*CAN_BITRATE_NOMINAL)) == 0U) { status = ptrCAN->SetBitrate (ARM_CAN_BITRATE_NOMINAL, CAN_BITRATE_NOMINAL, ARM_CAN_BIT_PROP_SEG (7U) | ARM_CAN_BIT_PHASE_SEG1(1U) | ARM_CAN_BIT_PHASE_SEG2(1U) | ARM_CAN_BIT_SJW (1U)); } else if ((clock % (12U*CAN_BITRATE_NOMINAL)) == 0U) { status = ptrCAN->SetBitrate (ARM_CAN_BITRATE_NOMINAL, CAN_BITRATE_NOMINAL, ARM_CAN_BIT_PROP_SEG (7U) | ARM_CAN_BIT_PHASE_SEG1(2U) | ARM_CAN_BIT_PHASE_SEG2(2U) | ARM_CAN_BIT_SJW (2U)); } else { return false; } if (status != ARM_DRIVER_OK) { return false; } rx2_obj_idx = 0xFFFFFFFFU; tx2_obj_idx = 0xFFFFFFFFU; for (i = 0U; i < num_objects; i++) { can_obj_cap = ptrCAN->ObjectGetCapabilities (i); if ((rx2_obj_idx == 0xFFFFFFFFU) && (can_obj_cap.rx == 1U)) { rx2_obj_idx = i; } else if ((tx2_obj_idx == 0xFFFFFFFFU) && (can_obj_cap.tx == 1U)) { tx2_obj_idx = i; break; } } if ((rx2_obj_idx == 0xFFFFFFFFU) || (tx2_obj_idx == 0xFFFFFFFFU)) { return false; } status = ptrCAN->ObjectSetFilter(rx2_obj_idx, ARM_CAN_FILTER_ID_EXACT_ADD, 0xfff, 0U); if (status != ARM_DRIVER_OK) { return false; } status = ptrCAN->ObjectConfigure(tx2_obj_idx, ARM_CAN_OBJ_TX); if (status != ARM_DRIVER_OK) { return false; } status = ptrCAN->ObjectConfigure(rx2_obj_idx, ARM_CAN_OBJ_RX); if (status != ARM_DRIVER_OK) { return false; } status = ptrCAN->SetMode (ARM_CAN_MODE_NORMAL); if (status != ARM_DRIVER_OK) { return false; } return true; } void CANWrite_MS (int ECU, unsigned char data[], char noReply) { _LEDON (BLUE); osDelay(1);_LEDOFF (BLUE); // sendCompleted=false; if (!noReply) ID_Read=0; memset(&rx2_data, 0U, 8);//clear data. memset(&tx2_msg_info, 0U, sizeof(ARM_CAN_MSG_INFO)); tx2_msg_info.id = ECU; ptrCAN->MessageSend(tx2_obj_idx, &tx2_msg_info, data, 8U); } long CANRead_MS (int ECU, unsigned char data, char position) { memset(&command_Data, 0U, 8); for (int t=0;t <_TIMEOUT;t++) { osDelay(10); printf("read:ID_Read &i \n", ID_Read); if (ID_Read > 0) { if (ECU == 0 ) { memcpy(&command_Data, &rx2_data,8); if (data != 0) { if (command_Data[position] == data) return ID_Read; } else return ID_Read;
