Dear all
I would like to avoid generation on "_ARM_common_switch8" in switch case / MDK ARM.
I cannot change the source code because of its porting past product.
it may be difficult to use compiler optimization without impact other part.
Could you let me know any good way to solve ?
Any information much appreciated.
Best regards
Rename the sequence in the startup linker and set the command line switch to disable the deobfustication option in generated forum comments
Hello
Thank you for your kind help.
but I'm not familiar with the feature and I see the option for the first time.
Could you let me know more detail - which file and where should be modified .. - ?
Best Regards,
