Hello, I am quite new to C/C++ and Keil. I am using the following:
nrf52832_xxaa (Cortex M4) Keil uVision 5.24.2.0
I have some existing C++ code which I had used on another project and am looking to implement it on the nrf52. However I am having problems with using Keil and C++. Specifically, on the definition of a struct, as shown below:
const nrf_drv_twi_config_t twi_lm75b_config = { .scl = ARDUINO_SCL_PIN, .sda = ARDUINO_SDA_PIN, .frequency = NRF_TWI_FREQ_100K, .interrupt_priority = APP_IRQ_PRIORITY_HIGH, .clear_bus_init = false };
I am getting the following errors:
*** Using Compiler 'V5.06 update 5 (build 528)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin' Build target 'nrf52832_xxaa' compiling main.cpp... ..\..\..\main.cpp(153): error: #29: expected an expression .scl = ARDUINO_SCL_PIN, ..\..\..\main.cpp(154): error: #29: expected an expression .sda = ARDUINO_SDA_PIN, ..\..\..\main.cpp(155): error: #29: expected an expression .frequency = NRF_TWI_FREQ_100K, ..\..\..\main.cpp(156): error: #29: expected an expression .interrupt_priority = APP_IRQ_PRIORITY_HIGH, ..\..\..\main.cpp(157): error: #29: expected an expression .clear_bus_init = false ..\..\..\main.cpp(121): warning: #177-D: function "data_handler" was declared but never referenced __STATIC_INLINE void data_handler(uint8_t temp) ..\..\..\main.cpp: 1 warning, 5 errors ".\_build\nrf52832_xxaa.axf" - 5 Error(s), 1 Warning(s). Target not created.
I have tried simplifying the case down and declaring the struct in the main.cpp,
typedef struct { bool peeled; ///< SCL pin number. } apple; void test_init (void) { const apple red = { .peeled = true }; }
but the same problem occurs
*** Using Compiler 'V5.06 update 5 (build 528)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin' Build target 'nrf52832_xxaa' compiling main.cpp... ..\..\..\main.cpp(175): error: #29: expected an expression .peeled = true ..\..\..\main.cpp(121): warning: #177-D: function "data_handler" was declared but never referenced __STATIC_INLINE void data_handler(uint8_t temp) ..\..\..\main.cpp: 1 warning, 1 error ".\_build\nrf52832_xxaa.axf" - 1 Error(s), 1 Warning(s). Target not created. Build Time Elapsed: 00:00:00
I have included my compiler settings here: https://ibb.co/imk6HG
Any help on this would be greatly appreciated
In addition, I have attached my compiler control string:
--c99 -c --cpu Cortex-M4.fp -D__EVAL -g -O2 --apcs=interwork --split_sections -I ../../../config -I ../../../../../../components -I ../../../../../../components/boards -I ../../../../../../components/drivers_nrf/common -I ../../../../../../components/drivers_nrf/delay -I ../../../../../../components/drivers_nrf/hal -I ../../../../../../components/drivers_nrf/nrf_soc_nosd -I ../../../../../../components/drivers_nrf/twi_master -I ../../../../../../components/drivers_nrf/uart -I ../../../../../../components/libraries/atomic -I ../../../../../../components/libraries/balloc -I ../../../../../../components/libraries/bsp -I ../../../../../../components/libraries/experimental_log -I ../../../../../../components/libraries/experimental_log/src -I ../../../../../../components/libraries/experimental_memobj -I ../../../../../../components/libraries/experimental_section_vars -I ../../../../../../components/libraries/strerror -I ../../../../../../components/libraries/util -I ../../../../../../components/toolchain -I ../../.. -I ../../../../../../external/fprintf -I ../../../../../../external/segger_rtt -I ../config -I ../../../../../../components/drivers_nrf/rtc -I ../../../../../../components/drivers_nrf/clock -I ../../../../../../components/libraries/timer -I./RTE/_nrf52832_xxaa -IC:/Keil_v5/ARM/PACK/ARM/CMSIS/4.5.0/CMSIS/Include -IC:/Keil_v5/ARM/PACK/NordicSemiconductor/nRF_DeviceFamilyPack/8.15.0/Device/Include -D__UVISION_VERSION="524" -D_RTE_ -DNRF52 -DBOARD_PCA10040 -DBSP_DEFINES_ONLY -DCONFIG_GPIO_AS_PINRESET -DFLOAT_ABI_HARD -DNRF52 -DNRF52832_XXAA -DNRF52_PAN_74 -o .\_build\*.o --omf_browse .\_build\*.crf --depend .\_build\*.d
You are trying to initialise the fields of a struct using designated initialisers - but these are not supported in C++
stackoverflow.com/.../why-does-c11-not-support-designated-initializer-lists-as-c99
Thank you, that makes sense now.
