I have a linker with extension .ld (is the format of the linker using the GCC Compiler (GNU)) and I want to translate it to the scatter linker with extension .sct.
I have some doubts in the translation. Firstly, in the creation of the memory sections. In my linker I have the following memory description:
MEMORY { FLASH_1(rx) : ORIGIN = 0x08000000, LENGTH = 1K
FLASH_2(rx) : ORIGIN = 0x08000400, LENGTH = 1K
FLASH_3 (rx) : ORIGIN = 0x08000800, LENGTH = 254K
RAM (xrw) : ORIGIN = 0x20000000, LENGTH = 16K
MEMORY_B1 (rx) : ORIGIN = 0x60000000, LENGTH = 0K }
My translation to the scatter format is the following:
LR_FLASH1 0x08000000 0x00000400 { ER_FLASH1 0x08000000 0x00000400 {
.ANY (+RO) }
RW_RAM 0x20000000 0x00004000 {
.ANY (+RW +ZI) } }
LR_FLASH2 0x08000400 0x00000400 { ER_FLASH2 0x08000400 0x00000400 {
.ANY (+RO) } }
LR_FLASH3 0x08000400 0x0003F800 { ER_FLASH3 0x08000400 0x0003F800 {
Is this description correct? Where have I to put the *(InRoot$$Sections)? Any information or comment about this will be appreciated.
Thank you very much.
it would be easier to read of you posted your linker file stuff as for source code
Sorry, here is my source code:
Definition of the memory in .ld linker: MEMORY { FLASH_BOOTLOADER (rx): ORIGIN = 0x08000000, LENGTH = 1K FLASH_UPDATER (rx) : ORIGIN = 0x08000400, LENGTH = 1K FLASH_APP (rx) : ORIGIN = 0x08000800, LENGTH = 254K RAM (xrw) : ORIGIN = 0x20000000, LENGTH = 16K MEMORY_B1 (rx) : ORIGIN = 0x60000000, LENGTH = 0K } Translation for the .sct linker: LR_FLASH1 0x08000000 0x00000400 { ER_FLASH1 0x08000000 0x00000400 { .ANY (+RO) } RW_RAM 0x20000000 0x00004000 { .ANY (+RW +ZI) } } LR_FLASH2 0x08000400 0x00000400 { ER_FLASH2 0x08000400 0x00000400 { .ANY (+RO) } } LR_FLASH3 0x08000400 0x0003F800 { ER_FLASH3 0x08000400 0x0003F800 { .ANY (+RO) } }
