Memory alignment issues with global buffer
We have a cortex M4F controller, using Keil uVision5 to compile and J-Link base to debug our applications. In our application we have a uint8 type global buffer of some x size, our issue is when we do memset for this global buffer controller is going to hardfault handler, we found the problem is with memory alignment for the global buffer and the problem is fixed by adding __attribute__((aligned)) to the global buffer
 uint8_t global_buf[GLOBAL_BUFF_LEN] __attribute__((aligned));
Can someone suggest any compiler options which would fix this issue without adding something to my code (we don't want to align all the the buffers in use).
  • If that's the problem, then the only way to solve it is to get your memory alignment correct!
    "we don't want to align all the the buffers"
    But if the CPU requires them to be aligned - you just can't do that!
    Anyhow, why do you not want them aligned?
    You need to give more details of what, exactly, you're doing if you want people to be able to understand it and make suggestions.
    What, exactly, are you doing that causes the (mis-)alignment to be a problem?
