Incorrect linker region symbol
I try to use linker-generated region symbols to programmatically obtain the size of flash memory consumed by my app.
When I compile it, compiler gives me this:
Program Size: Code=11688 RO-data=576 RW-data=28 ZI-data=6068
So I figure out that used flash size is Code+Ro = 11688 + 576 = 12264 bytes.
Then I write this code to obtaint this size programmatically:
extern unsigned int Image$$ER_IROM1$$Length;
static const uint32_t size_bytes = (uint32_t) &(Image$$ER_IROM1$$Length);
However this variable is equal to 11892 (0x2E74) which is less then shown by compiler output. I then go and obtain linker symbol Image$$ER_IROM1$$Limit and it's equal to 0x08002E74. My flash memory begins at 0x08000000 so it also shows less used memory.
I then go and check memory window and I see that there is some non-zero values beyond address 0x08002E74 so I guess linker is indeed wrong here.
I use this (generated by Keil) scatter file:
LR_IROM1 0x08000000 0x00030000  {    ; load region size_region
  ER_IROM1 0x08000000 0x00030000  {  ; load address = execution address
   *.o (RESET, +First)
   *(InRoot$$Sections)
   .ANY (+RO)
  RW_IRAM1 0x20000000 0x00007000  {  ; RW data
   .ANY (+RW +ZI)
  RW_IRAM2 0x20007000 0x00001000  {
    MDR32F9Qx_eeprom.o (+RO)
   .ANY (+RW +ZI)
What am I doing wrong? How can I obtain the correct size of used flash?
