Hello All,
I have the #define OS_TIMERS 1 in the conf file; but os_tmr_create() is always returning NULL - does this work on RTOS v1?
I have the v1.0 files installed; I am not able to upgrade this project to RTOS v2.
Thanks In Advance, John W.
Check below link: http://www.keil.com/forum/20906/
Non answer.
Unless the return value is osOK - like in using the other form of user timers: osTimerCreate() - which DOES work.
And I never saw os_tmr_call() ever work - couldn't even set a breakpoint on it in the debugger.
It apparently does not work. It would be great if Keil could publish some type of official post on this.
The revision history doesn't address these functions (os_tmr...) directly.
The lack of attention to detail and the cornucopia of misinformation on this forum is breathtaking.
Regards, John W.
