Hi guys,
I'm attempting to setup PC-Lint in a Keil MDK project, however it's of course throwing up a huge number of errors for my Software Packs and Standard Library files. I have all 'Include Project Information' boxes checked in the PC-Lint Options, except for Verify 'Software Pack' includes.
Would anyone be able to advise the most effective approach to ignore these files?
Many thanks
Actually this is the right approach and should already exclude (most) messages. Important is that the library path is correct added as shown under "Example content of single file target_F.lnt" on http://www.keil.com/support/man/docs/uv4/uv4_ut_pclint_config.htm
The dialog options are described: http://www.keil.com/support/man/docs/uv4/uv4_dg_lintsetup.htm
Thank you very much.
This resolved most problems, I also discovered I was using "" instead of <> for some of my library includes, also causing incorrect detection.
