I'm trying to draw a supply scheme for a class D integrated amplifier.
It requires 21V to 24V power supply and about 6/7A of current at 24V. The input is a car battery: 10V to 14.4V.
I've a few questions:
Is the NE555 usable for this scope? How much output current this circuit have? If the answers to the first two are: "no" and "too low" can you suggest a circuit scheme that it's my case? EDIT: If you did not understand well, the scheme of this DC boost must be added to the PCB of the amplifier. Also, the output current can also be 3A, i will put two of this circuit in parallel with diodes.
Here is the datesheet of ne555n:www.componentschip.com/.../NE555N.html
What resistance with what value I've to change to get a 21-24V output? Because it is adjustable, and it want fixed.
You'll find some Keil related product documentation here:
http://www2.keil.com/mdk5/docs
First read all the way through it, then come back to ask a relevant question to a Keil product.
Looks like componentschip are trying to join kynix at the Spam game:
http://www.keil.com/forum/62486/
http://www.keil.com/forum/62804/#/msg206189
