Does anyone have experience with the st32f205/207 using both usb & can?
//really? "both usb @nd can" Messages cannot contain the spam word "husb@nd". Fix your spam filter guys...
silver.arm.com/.../preload.tsh
I really need to find a working solution but I can not debug Keil usb code. Sadly they can not help.
We need to have a st32f2xx chip operating on 1 usb and 1 can network simultaneously. Preferences; Using the stf32f205 Using the USB FS not HS Both Cans 1 and 2 at once or at least 1 while usb is in use. If USB must be disable during can data transfers that is ok.
I was able to make it work, I just had RTE expecting hardware not attached causing a hang.
