Hey
I want to use stm32f0 by ws2812 and keil. this is my code
/* * light weight WS2812 lib - ARM Cortex M0/M0+ version * * Created: 07.07.2013 * Author: Tim (cpldcpu@gmail.com) */
#include "light_ws2812_cortex.h"
/* * The total length of each bit is 1.25µs (25 cycles @ 20Mhz) * At 0µs the dataline is pulled high. * To send a zero the dataline is pulled low after 0.375µs * To send a one the dataline is pulled low after 0.625µs */
#define ws2812_ctot (((ws2812_cpuclk/1000)*1250)/1000000) #define ws2812_t1 (((ws2812_cpuclk/1000)*375 )/1000000) // floor #define ws2812_t2 (((ws2812_cpuclk/1000)*625+500000)/1000000) // ceil
#define w1 (ws2812_t1-2) #define w2 (ws2812_t2-ws2812_t1-2) #define w3 (ws2812_ctot-ws2812_t2-5)
#define ws2812_DEL1 " nop \n\t" #define ws2812_DEL2 " b .+2 \n\t" #define ws2812_DEL4 ws2812_DEL2 ws2812_DEL2 #define ws2812_DEL8 ws2812_DEL4 ws2812_DEL4 #define ws2812_DEL16 ws2812_DEL8 ws2812_DEL8
void ws2812_sendarray(uint8_t *data,int datlen) { uint32_t maskhi = ws2812_mask_set; uint32_t masklo = ws2812_mask_clr; volatile uint32_t *set = ws2812_port_set; volatile uint32_t *clr = ws2812_port_clr; uint32_t i; uint32_t curbyte;
while (datlen--) { curbyte=*data++;
asm volatile( " lsl %[dat],#24 \n" " movs %[ctr],#8 \n" "ilop%=: \n" " lsl %[dat], #1 \n" " str %[maskhi], [%[set]] \n" #if (w1&1) ws2812_DEL1 #endif #if (w1&2) ws2812_DEL2 #endif #if (w1&4) ws2812_DEL4 #endif #if (w1&8) ws2812_DEL8 #endif #if (w1&16) ws2812_DEL16 #endif " bcs one%= \n" " str %[masklo], [%[clr]] \n" "one%=: \n" #if (w2&1) ws2812_DEL1 #endif #if (w2&2) ws2812_DEL2 #endif #if (w2&4) ws2812_DEL4 #endif #if (w2&8) ws2812_DEL8 #endif #if (w2&16) ws2812_DEL16 #endif " sub %[ctr], #1 \n" " str %[masklo], [%[clr]] \n" " beq end%= \n\t" #if (w3&1) ws2812_DEL1 #endif #if (w3&2) ws2812_DEL2 #endif #if (w3&4) ws2812_DEL4 #endif #if (w3&8) ws2812_DEL8 #endif #if (w3&16) ws2812_DEL16 #endif
" b ilop%= \n\t" " end%=: \n\t" : [ctr] "+r" (i) : [dat] "r" (curbyte), [set] "r" (set), [clr] "r" (clr), [masklo] "r" (masklo), [maskhi] "r" (maskhi) ); } }
but i have a problem 1-light_ws2812_cortex.c(45): error: #20: identifier "asm" is undefined but if i change asm to __asm the error change to light_ws2812_cortex.c(105): error: #18: expected a ")" :ctr] "+r" (i) how can i fix it?
Thanks for showing us how to convert the gcc inline assemblier code to ARM. It looks like the problem is caused by this statement:
I think this is a branch to current PC + 2 but the . notation is not supported within __asm. I have tried to use the __current_pc intrinsic but that generates additional errors when used within __asm.
By changing the line to:
#define ws2812_DEL2 " nop\n"
and compiling and flashing. Pressing reset several times will cause the WS2812 to light which shows the code is working but the timing is wrong.
You should try replacing the branch with a series of nops. On an ARM (and many others), the branch instruction is used because it takes more cycles to execute than many others.
Of course, you could also consider scrapping the code and doing it properly. The SPI can easily be used to drive one of these LEDs and the code would be far easier to maintain and port to different processors, speeds etc.
