Hey guys, I can't seem to get I2C working with LPC2148. The problem arise when I transfer data. Slave device (I2C debugger in Proteus) doesn't respond. Neither ACK nor NACK. It just get paused. Although when I Write Slave address, Ack is given by Slave. PCLK is 60MHz.
#define I2EN (1<<6) //Enable/Disable bit #define STA (1<<5) //Start Set/Clear bit #define STO (1<<4) //Stop bit #define SI (1<<3) //Serial Interrupt Flag Clear bit #define AA (1<<2) //Assert Acknowledge Set/Clear bit void I2C0_Init (void) // initialise i2c { I2C0CONCLR = STA|STO|AA|SI; // clear start, stop, aa and interrupt bit I2C0CONSET = I2EN; // set enable bit } bool I2C0_WaitForSI (void) //wait for si flag to set { int timeout = 0; while (!(I2C0CONSET&SI)) // while si bit in conset is not set { timeout++; if (timeout>1000) return false; } return true; } void I2C0_SendStart (void) //send start or r-start { I2C0CONCLR = STA|STO|SI|AA; //clear start, stop, aa, interrupt bit I2C0CONSET = STA; // enable start bit I2C0_WaitForSI(); //wait for above condition to complete } void I2C0_SendStop (void) { I2C0CONSET = STO; //set stop bit } void I2C0_Tx (unsigned char data) { I2C0DAT = data; //load data into register I2C0CONCLR = STA|SI|STO; // clear start,interrupt and stop to transfer data I2C0_WaitForSI (); //wait for above condition to complete } //unsigned char I2C0_Rx (bool last) //{ // if (last) I2C0CONCLR = AA; //is last address, than clear aa to send nack. // else I2C0CONSET = AA; //otherwise send ack to keep receiving data. // I2C0CONCLR = SI; //clear si to receive data. // I2C0_WaitForSI (); //wait for data to be received. // return I2C0DAT; //} int main () { PINSEL0 |= (1<<4)|(1<<6)|(0<<5)|(0<<7); //set i2c scl and sda PINSEL2 = PINSEL1= 0; VPBDIV=0x01; //pclk is 60Mhz I2C0SCLH=300; // 100 khz rate I2C0SCLL=300; IODIR1 = 0xffffffff; unsigned char slave_address = 0xA0; unsigned char data = '1'; I2C0_Init (); I2C0_SendStart(); I2C0_Tx (slave_address); I2C0_SendStop(); I2C0_SendStart (); I2C0_Tx (slave_address); I2C0_Tx (data); I2C0_SendStop(); }
Does a real I2C device respond?
The LPC2148 is an NXP device; NXP own & invented I2C - surely they must have working examples?
http://www.lpcware.com
www.nxp.com/.../single-chip-16-bit-32-bit-microcontrollers-512-kb-flash-with-32-segment-x-4-lcd-driver:LPC2157FBD100?fsrch=1&sr=1&pageNum=1
Actually I don't have a real I2C. That's why I am using I2C debugger in simulator. I'll try using my PIC microcontroller as slave and revert back.
