It looks like there is no such options.
Not sure what you mean by "dump the full compilation pass"? Please clarify?
uVision Listing options: http://www.keil.com/support/man/docs/uv4/uv4_dg_adslst.htm
Compiler Command-line Options: www.keil.com/.../armcc_chr1359124898004.htm
"Just like GCC"
Maybe say which option(s) ?
Redirect the ouptup with teh >> cymbal . you have to do it to the comand line and you probebly have to change. Shirtcut on the desktol. But ihavnottried it and idontknow if it isdocument so youmust tryitfirst andtesr it.
If it doesnotwork try in wine ðŸ·
I mean command-line option, --dump-parse-tree Thanks!
I don't see that one listed:
gcc.gnu.org/.../Debugging-Options.html
What, exactly, are you looking for? What are you trying to do?
Anything like this:
stackoverflow.com/.../how-can-i-see-parse-tree-intermediate-code-optimization-code-and-assembly-code
I want the internal compilation data from IR, such as -fdump-tree-all and -fdump-rtl-all options, maybe help. Thanks!
But why?
I think this is probably something you're going to have to discuss direct with Keil technical support.
The stuff you're talking about for GCC is to do with its internal workings; remember that GCC is open-source, but Keil is not - so, if they will discuss it at all, it might have to be under NDA...
