Hello. I have a problem while opening my project in Keil uVision5. I get an error - "An error occured while reading the project file. Line 1(#document) Fatal Message: invalid byte '¶' at position 1 of 1-byte sequence." What should I do to solve this problem?
Aren't the files just ASCII XML type things?
I suppose you could view in a hex editor, and ponder what you did or were doing that resulted in the file getting snarled up?
Delete the file and start over?
Does it impact all project files? Are other tools auto-generating, or modifying the files? CubeMX?
