error C129 : missing ";" before '0' anyone help me figure it out please it be much appreciated as per i am new to this thank you and have a nice dau to all
ORG 0h Coma EQU 30H UNIT EQU 31h Dozens EQU 32h HUNDREDS EQU 33h MENU_OK EQU 34h D_SETTING1 EQU 35h D_SETTING2 EQU 36h D_DISPLAY1 EQU 37h D_DISPLAY2 EQU 38h D_TEMPERATURE1 EQU 39h EQU D_TEMPERATURE2 3Ah REVERSE EQU 3BH REST EQU 3CH T_MENU BIT P3.0 T_DOWN BIT P3.1 T_UP BIT P3.2 LAMP BIT P3.3 P_TEMPERATURE BIT P3.4 P_ZX BIT P3.5 ACALL SET_AWAL START: ACALL TEMPERATURE ACALL MENU ACALL APPEAL ACALL CONVERSION JMP START TEMPERATURE: MOV R3, # 64H MOVE TMOD,# 15H MOV TLO, #00H MOV THO, #00H SETB TR0 AGAIN: MOVE TL1, #0EFH MOV TH1, #0D8H SETB TR1 ACALL CONVERSION WAIT: JNB TF1, WAIT CLR TR1 CLR TF1 DJNZ R3, AGAIN CLR TR0 CLR TF0 END_T: MOV D_TEMPERATURE1, TL0 MOV D_TEMPERATURE2, TH0 MOV D_DISPLAY1, D_TEMPERATURE1 MOV D_DISPLAY2, D_TEMPERATURE2 ACALL CONVERSION END_TEMPERATURE: RET MENU: JB T_MENU, CHECKING_MENU ACALL DELAYT ACALL DELAYT MOV A,MENU_OK CJNE A,# 0h, SETTING_OK MENU_OK MOV,# 1h JMP UP SETTING_OK:MOV MENU_OK, # Oh JMP END_MENU UP: JB T_UP, DOWN MOV A,MENU_OK CJNE A, # 1H,MENU ACALL DELAYT D_SETTING1 INC. MOV D_DISPLAY1, D_SETTING1 MOV D_DISPLAY2, D_SETTING2 ACALL CONVERSION MOV A, D_SETTING1 CJNE A, #0FFH, UP CLR D_SETTING1 D_SETTING2 INC. MOV D_DISPLAY1, D _SETTING1 MOV D_DISPLAY2, D_SETTING2 ACALL CONVERSION DOWN: JB T_DOWN, MENU MOV A, MENU_OK CJNE A, # 1H, MENU ACALL DELAYT MOV A, D_SETTING1 CJNE A, #00D, less_LSB MOV A, D_SETTING2 CJNE A,#00D,less_MSB JMP MENU less_LSB: DEC D_SETTING1 MOV D_DISPLAY1,D_SETTING1 MOV D_DISPLAY2, D_SETTING2 ACALL CONVERSION JMP DOWN less_MSB: DEC D_DETTING2 MOV D_SETTING1, # 0FFH MOV A, D_SETTING1 DA A MOV D_DISPLAY1, D_SETTING1 MOV D_DISPLAY2, D _SETTING2 ACALL CONVERSION JMP DOWN CHECKING_MENU: MOV A, MENU_OK CJNE A, # 0h, SETTINGS JMP END_MENU SETTINGS: MOV D_DISPLAY1, D_SETTING1 MOV D_DISPLAY2, D_SETTING2 ACALL CONVERSION JMP UP END_MENU:RET APPEAL: MOV A, D_SETTING1 CJNE A, D_TEMPERATURE1, CHECKING1 JMP B_MSB CHECKING1: SubB A, D_TEMPERATURE1 JC B_MSB JMP LIFE B_MSB: MOV A, D_SETTING2 CJNE A, D_TEMPERATURE2, CHECKING2 JMP STOP CHECKING2: SubB A, D_TEMPERATURE2 JC SWITCH JMP END_B SWITCH: SETB LAMPS END_B: RET CONVERSION: MOV R1, D_DISPLAY2; MSByte MOV R2, D_DISPLAY1; LSByte MOV R4, # 00D MOV R5, # 00D MOV R6, # 00D MOV R7, # 00D MOV B, # 10D MOV A, R2 DIV AB MOV R4, B; 7,6,5,4 BCD DATA IS MOV B, # 10 DIV AB MOV R5, B MOV R6, A ( this in number 129 saying error) CJNE R1, # 0h, HIGH_BYTE; CHECK FOR HIGH BYTE SJMP END_KONVERSI HIGH_BYTE : MOV A, # 6 ADD A,R4 MOV B, # 10 DIV AB MOV R4, B ADD A, # 5 ADD A, R5 MOV B, # 10 DIV AB MOV R5, B ADD A, # 2 ADD A, R6 MOV B, # 10 DIV AB MOV R6, B ADD A, R7 DA A MOV R7, A DJNZ R1, HIGH BYTE END_KNOVERSI:MOV coma, R4 MOV UNITS, R5 MOV tens, R6 HUNDREDS MOV,R7 ACALL DISPLAY RET DISPLAY: MOV A, coma; Segment1 ADD A, # 10H SWAP A MOV P1, A ACALL DELAY MOV A, UNIT; Segment2 ADD A, # 20H SWAP A MOV P1,A ACALL DELAY MOV A, tens; Segment 3 ADD A, # 40h SWAP A MOV P1, A ACALL DELAY
MOV A, HUNDREDS; SEGMENT 4 CJNE A, # 0h CONTINUES MOV A, # 0FH KEEP: ADD A, # 80h SWAP A MOV P1, A ACALL DELAY RET SET_START:MOV MENU_OK # 0h; 1 =MENU, 0=OK MOV D_SETTING1, #0h MOV D_SETTING2, #0H MOV D_DISPLAY1, #0h MOV D_DISPLAY2, #0h RET DELAY: MOV 42H, # 2H LAGI_1: MOV 43H, # 0FAH LAGI_2:DJNZ 43H, # LAGI_2 DJNZ 42H, LAGI_1 RET DELAY: MOV 42H, # 0A0H AGAIN_3: MOV 43H, # 0F0H AGAIN_4: DJNZ 43H, # AGAIN_4 DJNZ 42H, LAGI_3 RET END
C... errors come from the 'C' Compiler
http://www.keil.com/support/man/docs/c51/c51_er_reference.htm
A... errors come from the Assembler
http://www.keil.com/support/man/docs/a51/a51_er_reference.htm
So you're clearly using the wrong tool!
