Can anyone explaine this logic?
while (1)
        USARTdrv->Receive(&cmd, 1);          /* Get byte from UART */
        osSignalWait(0x01, osWaitForever);
        if (cmd == 13)                       /* CR, send greeting  */
          USARTdrv->Send("\nHello World!", 12);
So the USARTdrv->Receive and the osSignalWait need to be ran over and over? Is the osSignalWait not sufficient by itself?
I'm trying to make this work but I see nothing that explains how it works. If the signal is set in
if (event & mask) { /* Success: Wakeup Thread */
then how is this checked in a loop? I figured this line just loops until met? osSignalWait(0x01, osWaitForever);
Is that not how it works?
  • If cmd can change outside normal program flow, ie across the osSignalWait() call, it should be defined as being volatile, especially if it is a local/auto variable where the compiler assumes other subroutines won't be changing it.
    If in doubt with things, look at the compiled code, and review the logic the CPU is applying..
